Building on top of a slab
Old 08-12-16, 01:15 PM
N
Question Building on top of a slab
when building ontop of slabs what must be placed down first in order to make everything level and safe.
thank you.
this is for decking. Cheers
Old 08-12-16, 01:42 PM
Received 1,190 Upvotes on 1,147 Posts
Welcome to the forums.
Sorry, need a whole lot more information and details to understand what you're asking.
Old 08-12-16, 02:37 PM
W
Received 60 Upvotes on 52 Posts
Deck on Slab
If you talking about deck joists directly on the slab, then you need to locate the highest point of the slab and shim all joists to be level with the joist(s) located at the highest point.
Old 08-12-16, 02:45 PM
Received 742 Upvotes on 648 Posts
..... but it isn't a great idea to build a deck just over a slab as rain water can get it but lack of ventilation prevents it from drying out in a timely manner = short life for the deck
Old 08-12-16, 02:58 PM
Received 125 Upvotes on 110 Posts
Just a really bad idea!
What's wrong with the slab now?
There's been hundreds of people showing what happens when this has been tried on this and any DIY web sites.
Joist and decking rot out, decking is so high water gets in under the threshold and takes out the flooring or more inside the home.
