Copper Green wood treatment or ?
Old 08-28-16, 12:57 PM
P
Is copper green an acceptable way to treat wood that has rotted? Will it effectively prevent further decay?
Old 08-28-16, 01:23 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Nothing will stop wood from rotting if it has already started. Copper green may help the wood that is in good shape, but the rotted wood needs attention beyond the Copper green's capabilities.
Old 08-29-16, 03:21 AM
Received 674 Votes on 597 Posts
It's almost always better to replace or cut out the rotten part and patch the wood. Can you further elaborate on what you have going on?
Old 08-29-16, 10:19 AM
P
Nothing specific. I was just wondering about the copper green product and it's abilities to do the same thing as CPES without the structural support which is stop rot.
Of course you dig, cut, or otherwise remove as much as possible before application.
Old 08-29-16, 12:54 PM
C
Received 225 Votes on 183 Posts
There are several marine products that can stop wood rot and strengthen the damaged area. I have used an epoxy product called Git Rot with good success.
If you have a lot of rotted wood the marine stuff may be cost prohibitive.
Old 08-30-16, 01:15 PM
P
Makes sens. So, if we apply the copper green to the good wood where it meets the rotted wood and do so thoroughly then can we expect the good wood to remain 'good' ?
This seems to be the case with Clear Penetrating Epoxy Sealer (CPES), and I'm trying to verify if the copper green is just as effective given no structural issues
