The back yard leaves stained the cement now?
I live in my condo that has lot of trees. The leaves dropped on my cement in my back yard. Now the leaves stained the cement now. How do I remove the stain from the cement?
If you have a pressure washer it can do wonders. You can also try a powdered laundry detergent that contains bleach and scrub with a stiff bristle brush. Then rinse thoroughly. In the future it is easier to get rid of the leaves before they stain than it is to remove the stains. And, the longer the leaves sit there the darker and harder it is to remove the stains.
