How should I affix plastic lattice?
Received 0 Votes
You should definitely pre-drill the plastic slightly larger than the screw size.
The type of screw depends on the installation but if outside should be a stainless steel pan head type screw.
A washer head or cabinet screw provides a larger head while using a smaller shaft, thus your hole can be a bit larger to accommodate the movement Gunguy mentioned. And I agree with Pete that stainless steel would be best.
Bud
Bud
