What to do with downspout
Howdy,
We plan on putting in a concrete patio in the backyard, however, there's a downspout smack in the middle of our planned patio. At the moment, we have a solid corrugated drain pipe attached to it and is buried in the ground.
What are your thoughts on what we should do with that downspout/drain pipe? Someone at work said, "replace the drain pipe with a solid PVC pipe and then pour the concrete over that", but I'm unsure if that's the right thing to do. I could remove the drain pipe and have it above the concrete patio, but the wife says that looks "ugly".
Dry wells and French drains don't work well in the soils around my house. They just can't accept water fast enough to be useful especially during larger rain events.
We can't see your patio area or the elevations but I would go with the smooth PVC to run under your patio. I would use schedule 40 (the type used for drain pipes inside homes) for it's greater strength. It will be difficult to find a fitting that mates the round sch 40 PVC to rectangular downspout but they do exist. Most big box home centers do not stock them so you may have to special order or find them online.
Could replace with PVC pipe but results are still the same.
