Sliding Screen Door Question
Old 09-07-17, 04:07 PM
A
Hi all. New homeowner here, so please excuse me if I should have figured this out on my own. To my credit, two people with more experience than I have looked at this and come up empty.
I want to put a sliding screen door on the door to my deck. There is a track for one, and a hook, and I even got the thing up before noticing this issue.
The regular door frame is made of metal (aluminum?) but I can't tell if that's true for the bottom of the half of the slider that doesn't move. At any rate, as you can see in the picture I have attached, there appears to have been some settling over the years or something. So the bottom has expanded, or bent, or I don't know, to the point that it's about half a centimeter off.
That little bit is enough to stop the screen door I want to put in from sliding. It's essentially functioning as a permanent and unwanted lock.
I want to fix this, to get it back in line, but I don't know how. If I push on the affected area, the door frame moves in slightly, then immediately bounces back.
Any advice is welcome. Thanks!
Old 09-07-17, 04:10 PM
A
Oops. Pic didn't work. Link:
https://************/yc7sbh3y
Old 09-07-17, 04:18 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
Follow this instead.............
