deck sealer
Old 10-12-17, 06:20 AM
margaretzbo's Avatar
deck sealer
hello everyone Im Margaret and new to this forum. we built a new deck over the summer and thinking about painting/ staining or just sealing? What would be the best way to go about it? and what are the best products out there to buy?
Old 10-12-17, 06:39 AM
Received 741 Upvotes on 647 Posts
Welcome to the forums Margaret!
First, what type of wood was used? Pressure treated wood needs to dry out from the PT process before you can get a good stain job. This can take anywhere from 6 weeks to 6 months, dependent on how wet it was when installed and the climate it's subjected to.
Next how you want the deck to look plays a part in what stain you should use. Clear sealers like Thompson's WaterSeal have a short life! typically 6-12 months. Toners or translucent stains do better but not as good as semi-transparent. Generally you'll find better coatings and advice at your local paint store - not a big box paint dept. Be sure to use a deck stain, sidings stains don't always do well on decks.
Old 10-19-17, 05:59 AM
Thank you for your reply. I found it very helpful... lots to consider.
