Is my deck cedar? (Newbie question)
Old 02-23-18, 08:13 AM
Bought this house last summer and want to freshen up the deck this spring before furnishing it with tables, chair and bbq. Just wondering if a definitive answer on the type of wood used on my deck is possible based on the attached photos.
Thanks,
Jack
Old 02-23-18, 08:42 AM
Received 79 Votes on 74 Posts
Just looks like weathered pressure treated decking to me.
XSleeper's Avatar
Received 716 Votes on 663 Posts
It sure looks like cedar to me. The UV light eventually turns it grey.
Old 02-23-18, 09:23 AM
2
Received 54 Votes on 46 Posts
Go underneath or find an area that has not been exposed to the weather. White cedar heartwood is a light reddish brown. Narrow sapwood is pale yellow-brown to almost white and is clearly demarcated from the heartwood. Red cedar will have reddish color and may have some darker red stripes. It turns gray quickly in the weather. Rough up the wood in a hidden area and check if it has a cedar smell.
Clean with 2 cups of Oyx-Clean in 5 gallons of water. Don't use chlorine bleach. That will eventually destroy the wood fibers.
Last edited by 2john02458; 02-23-18 at 09:25 AM. Reason: Added cleaning suggestions
Old 02-23-18, 11:53 AM
Received 330 Votes on 293 Posts
Chlorine bleach is fine provided you don't let it dry on the wood and rinse it well. It's my go to cleaner for decks/siding.
The odds are if you scrub a portion with bleach water and get it clean - we'd then be better able to identify the wood.
Old 02-24-18, 06:48 AM
W
Received 21 Votes on 20 Posts
In a protected, unweathered area, look for markings and tell us what they are. An example is SYP, which is Southern Yellow Pine.
Your profile does not give your location. Your general location would be a clue to the most likely species used.
Old 02-24-18, 07:10 AM
V
Received 1 Vote on 1 Post
Around here, some people use Eastern White Cedar for decking; but when installed, spacing is critical to allow for expansion and contraction. If an adequate space isn't provided, there'll be buckling.
You may be able to watch your decking when it rains and see how much of the gap between slats is swelled shut, and make a determination from that observation.
Also, Cedar is soft and doesn't wear well under foot traffic, and a wear pattern would be present if it were Cedar.
I think I agree with the others who suggested that it is aged pressure treated Spruce or Pine.
