How to add WHEELS to Boat Lift (retractable if possible!)
Received 0 Votes
Hey all - I have an older 3000 lb capacity cantilever style boat lift from Naylor Systems (A canadian brand based out of Lindsay, ON).
This beast was already tough to move - but two years ago a canopy was added to it - and now even with four people, it is terrible.
I have seen some of the wheels that can be attached to lifts, but once this thing is in the water, I will not be able to mess with bolts etc under the water.
I was hoping for some kind of retractable wheels I could install (something akin to the 'third' wheel on a trailer that you winch up and down when needed).
That way I could winch the wheels down, move the lift into position, and then winch them back up allowing the built in feet to rest on the ground. And when taking it out, I could even hook it up to my truck to drag out at the end of the year.
Any thoughts or ideas? They are all greatly appreciated!
Picture included is of the actual lift - a bit far away - but shows enough of the structure around the legs to be relevant.
Is the wheel provide force to the lift in both directions? Does the lift go down under the force of gravity or can you force it down with the lift wheel? I'm wondering if you could attach wheels to the lifting part of the frame then use the wheel to lower the wheels and lift the entire frame. Then once it's in the water turn the wheel to lift the temporary wheels out of the water for removal.
My family and friends have added many fixed dock wheels to boat lifts without any issues of the lift moving around on the wheels. Before going crazy with some type of retractable wheel system I would try it first with fixed wheels. Unless you have a very hard bottom the wheels will sink into the ground securing it in place.
If you do find the lift moves too much it would be easier to add spikes/anchors that drop down to secure the lift from moving.
Removing the wheels before putting the lift into the water would defeat the purpose of the wheels.
Received 0 Votes
Found this:
Smarte Jack Retractable Boat Lift Wheel System
It is the closest thing to what I was thinking!
