Second story deck: stair (rise/run) recommendation
I have calculated two different sizes for rise/ run of my second story deck- either (A) 15 steps with rise of 7 3/16and run if 10 3/8, or 14 steps with rise of 7 11/16 and run of 11 1/8. Anyone recommend one over the other? Thanks in advance for suggestion
I would suggest you go with A. See the stair guidelines in the DCA6. You will need an intermediate support for the stringers at 6 ft. (Maximum span)
http://www.awc.org/pdf/codes-standar...Guide-1804.pdf
