Need shade or roof ideas for my sunny deck
Old 06-16-18, 08:02 AM
D
Hello,
I built a deck last year and did not incorporate any type of roof or pergola for shade. My deck is approximately 18 feet deep and 20 feet wide. I have been looking at EVERYTHING that makes shade. I can't figure out way I want though.
I've looked at shade sails but don't want to stretch them to the railing because they would be too low to walk under then. I don't want posts added to the railing because I feel like it would strain my railing over time and also would look like a poorly planned afterthought of a roof.
Next, there Is only about 3 inches between the top of my door and the soffit. Not much room for the door to swing open and have a shade sail right above that.
Umbrellas don't cover enough for my liking. And I have to keep moving it to stay in the shade.
I don't see room for a retractable awning because I have a vent pipe on my roof close to the edge.
Can anyone picture any shade cover idea that would look attractive and also be possible without re-engineering my deck or anything?
I've been brainstorming for a year and can't figure this out.
Thanks for your time.
David
Size:  46.0 KBName:  p5.jpg
Old 06-16-18, 09:12 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Patio Sails, want to put one on the upper section of my deck/patio just haven't gotten to it yet.
https://www.doityourself.com/forum/a...1&d=1529165524
maarkr voted this post useful.
Old 06-16-18, 09:47 AM
B
Received 47 Upvotes on 43 Posts
I would go with one or more shade sails. They are very flexible in design and can be attached from the roof surface out to added (very secure) posts and not affect the deck railing.
IMO, the sails would look far better than a roll out awning or even a roof and they can cover the entire desired area.
Bud
Old 06-16-18, 04:05 PM
P
Received 1,950 Upvotes on 1,746 Posts
I too am a big fan of shade sails. With my patio I went a bit upscale/commercial with the installation taking extra care creating bomb proof anchorages for the sails. I use Tenshon sails and they have held up well for many years.
Old 05-07-19, 08:15 AM
D
Hi,
Unfortunately I am still trying to figure out shade for my deck
I have been considering building a roof. I want to know about snow loads.
I didn't plan any footings for roof when I build the deck. I wanted to attach a corrugated roof right on top of the decking. Do you think that will make my deck fail if there is a heavy snow? I am thinking that if there is a roof there will be the same amount of snow weight on the deck overall but the only added weight would be the weight of the roof itself.
Would the points of contact on the decking be to highly concentrated and cause failure like that?
In other words, all of the snow that is on the roof would normally have the weight spread out evenly over the decking but now it will be divided by the number of legs and that will be concentrated under each leg. I believe my deck is built plenty strong for snow as of right now without a roof.
Old 05-07-19, 09:51 AM
Received 3,593 Upvotes on 3,222 Posts
Since you haven't put where you live in your bio..... you'd need to post it here.
Old 05-07-19, 10:26 AM
D
Coopersburg Pennsylvania.. Is that for snow loads?
Old 05-07-19, 12:06 PM
P
What size and type footings does your deck have? Hint, I'm looking for specifics.
If you did not construct footers capable of supporting a roof load I would forget installing a rigid roof. Quite often people build decks with inadequate footers but if permits were taken and code followed then you might be in better shape.
There really is no part of a standard deck that can support a roof load. If installing roof support columns they should be directly on top of your deck columns or more ideally the columns/posts should extend all the way from ground to roof without interruption. Posts can be added on top of existing posts if properly fastened and braced. But, it all starts at the foundation/footer.
Old 05-21-19, 05:15 AM
D
OK drumroll please ..
This is finally what I have come up with. It is a free-standing roof with buried post footings. I like how it is coming along so far. the only problem which is a big problem is the whole thing is very wobbly since it is so top-heavy. I have not put any of the furring strips on top of the rafters yet. This is going to be a galvanized corrugated roof. I remember when I built my deck the whole thing was very wobbly until I put my deck boards on. But this free-standing roof is so wobbly I'm afraid that is not going to change much when I put the furring strips on. I know knee bracing is recommended on taller decks. The only problem is I can put knee bracing from post to beam on One Direction but there is nothing to attach my knee brace to going from post to rafter. Do you think this will get more solid when I get the roof fully on? I am putting the furring strips at 2 ft on Center.
Old 05-21-19, 07:57 AM
P
Do you have footings for your posts or are they just stuck in the ground?
Adding the roof won't help with stiffness. The only stiffness you'll have is in the posts themselves, how they are anchored and how they are connected together. Heavy steel brackets at the joints can help a lot but you'll still have flexing in the posts. You can also install diagonal bracing but that will interfere with using the deck.
Old 05-21-19, 08:29 AM
D
Yes I do have footings they are at least 17 in diameter footings. I have a feeling the metal braces are going to be pretty expensive the ones you are talking about. I think my best bet is to try to make some knee braces and make them in the best spots possible to not interfere with moving around the deck. The toughest one for me to figure out is the one near the door because the door opens so close to the inside corner. Also is it okay to brace from the post to a rafter? Or should I mount a board between two Rafters or more and put a brace from the post to the multi rafter board
Old 05-21-19, 08:58 AM
D
Also do I have to use 4x4 for the bracing or can 2x4 work. Or does it depend on the span. And is there a good way to determine the length of a brace or just bigger is better.
Old 05-21-19, 09:39 AM
P
Steel braces are relatively inexpensive as they are often just plate steel or angle brackets. Just much heavier duty than when home centers stock. I've even had them made at my local welding shop.
Old 05-21-19, 10:03 AM
D
is this kind of what you're talking about in the link below
https://www.homedepot.com/p/Simpson-...APT6/300068639
Old 05-21-19, 11:46 AM
D
I just cannot figure out how to brace the corner that is near the entry door. The door seems like it is going to be in the way unless I have a super steep brace that starts lower on the leg and doesn't go far on the beam. Any suggestions for that corner? And also when I'm going to brace the post to the rafter is there a good way to do that? The post to the beam is simple but the other direction is complicated for me
Old 05-21-19, 11:52 AM
P
Near the door you can use a heavy "T" bracket similar to what you linked. It will help with side to side (parallel to house) motion. Bracing to the rafters/joists can help in the other direction (motion towards/away from house). Then getting your roof securely screwed down will help a good deal with twisting.
Old 05-21-19, 12:49 PM
airmark's Avatar
Received 4 Upvotes on 3 Posts
Your beams look too small for the total roof snow load. I'm guessing they should be at least twice as heavy. I just paid an architect $1,300 to draw up plans for my covered patio which is 22 x 16. Free-standing hip roof set in piers 18 inch diameter by 36 inch deep for 4 posts. The joinery hardware between your post and beans is worrisome too weak for weight and high winds. You need specialty hardware for that connection. Probably cost more than $50 for each.
Old 05-21-19, 01:14 PM
D
Thanks Dane. I'll look into getting a heavy metal brace for that. I'm gonna have to shim it out because my beam is slimmer than the posts. I'm about to start the metal roofing. I didn't read the directions before I did this. Just read it now kinda. Recommends 16 oc perlin spacing. I just have purlins space 2 feet. Think it'll hold a Pennsylvania snow? We get plenty. I don't plan on walking on it ever.
Old 05-21-19, 01:20 PM
2
Received 356 Upvotes on 308 Posts
Do you really want or need a roof? As you can see the structure (pergola) provides plenty of shade by itself. You could also grow some ivy, wisteria or grapes on it.
Heavier connections as others have described and some solid blocking between rafters will stiffen the structure. Blocking will also help with shading when/if the sun is shining directly down/into the structure parallel to the rafters.
No roof=no snow load=less wind resistance, etc.
Old 05-22-19, 04:41 AM
D
I 100% definitely want a rainproof roof. I don't want a Shade Sail or anything like that. I really really really like the idea of a ton roof. That being said, I am interested in beefing up my connection between post and beam. The confusing part is there are slight gaps on each side of the beam because it's not quite as wide as the post. So I would have to shim it with something. But I definitely don't want to take out the old connections because it is already leveled and shimmed and mounted I just want to add some connectors.
The way I'm thinking about this roof is it's basically just a very tall deck. I've built my 18 x 20 deck couple years ago and snow loads have never been an issue. The only difference majorly between the roof and the deck is the height of the posts. I'm pretty confident after I decide how I want to do my knee braces, that that will strengthen and prevent much of the wobble. I'm going to go finish my tin roof and start deciding how I want to do those braces
Again, I appreciate all these tips and pointers.
  #21
Old 05-23-19, 07:34 AM
D
All the roof panels are on now and I have put on some knee braces for stability. The bracing has definitely helped a bunch making it much less wobbly than it was before. But it still does have a little bit of a shake if you do shake the structure. I'm okay with that though because I'm not going to be walking on top of the roof so no need to be solid as a rock. I will definitely put up some pictures of where it is at currently. The only problem is there are some drops of water that Splash from the roof through the openings between the two roofs and onto the deck. Not much but enough to be annoying and now I need to find out some kind of splash guard to install along the back Edge so that it drips back onto the roof and into the gutter.
Pictures to come in a couple hours
