Driveway Ditch
Old 09-03-18, 01:18 PM
N
Received 2 Upvotes on 2 Posts
Driveway Ditch
At the start of my gravel driveway is a dirt road some of which drains towards the driveway. I had dug out a little ditch at an oblique angle to convey water away from driveway and ultimately house. Unfortunately the dirt road keeps moving sand/dirt to fill the ditch intermittently. I am not at the house a lot to maintain it this ditch. So looking for more permanent solution I can drive over but intercepts the water and channels it away...
Old 09-03-18, 01:20 PM
Received 876 Upvotes on 767 Posts
A pic or two would give us a better idea of what you have going on.
Could you place rocks or other masonry between the ditch and the driveway?
Old 09-03-18, 01:22 PM
Marq1's Avatar
Received 1,211 Upvotes on 1,099 Posts
picture would help
you mention ditch and driving over so not sure what you have or looking for
Old 09-03-18, 03:53 PM
N
Looking up the eroded driveway to the gate and diversion area
You can see the railroad tie set in place with "ditch" area right beyond it (you can see I shoveled out some of the ditch and built up the mud temporarily to divert water
This is the culvert area to the left and top of the photo, I want it to head towards...(Picture is looking a different direction, you can see the railroad tie for perspective)
Old 09-04-18, 03:13 AM
You need to stop the water before it gets on your road. IMO you need a ditch on each side of your driveway.
Old 09-04-18, 09:28 AM
N
Just above my driveway is not my property and so I can only make improvements right before where the driveway starts. Thats what I am looking for. French drain with rock? Perforated pipe? Ditch?
Old 09-04-18, 05:40 PM
Tolyn Ironhand's Avatar
Received 917 Upvotes on 775 Posts
I installed a channel and grate at the top of my driveway before a hill to catch water otherwise it was washing out the hill. This is what I used: https://www.ndspro.com/products-html...in-grates.html
It works pretty good but the grate will clog up with gravel during heavy rains. Periodic cleaning is needed.
Old 09-05-18, 09:25 PM
N
Thats a good idea about the grates. I wonder if I can inlay a half pipe of corrugated metal at the bottom of the "ditch" and put the grate on top?
