Concrete slab holding water
Received 0 Votes
Hi, I have a 5x8 concrete slab under a deck that holds water for many days after it rains. (no sun) It has a dip in the middle and that is where the water pools... I was wondering if there is a product that I could spread over this that would fill the dip and I could feather it where it would roll the water away. There would not be anything of real weight stored on the slab (wheel barrow and burn barrel).. Thanks for any reply
Better idea than that would be to simply make two saw cuts just a 1/2" deep across the pad to divide it into 4 equal parts. (Cutting a + ) The water would then be able to drain out the ends of the saw cuts.
