Building a Bridge on a budget
Received 0 Votes
So I have a 1 acre pond that narrow near the house and I want to build a walk bridge about 5' wide to cross the pond. The span is about 40'. So I was going to put a support at the mid point of the span anchored into the bottom of the pond. I was thinking of using treated 2 x 10 x 20 and carriage bolting another 20' across where the board butt up to each other.to cross the span using 5 runs 12" on center. Do you think that will be enough to support say 2-3 people walking on it at the same time.
Never done it but if I was going to I would use 55 gallon barrels as flotation devices... build reasonable sized sections like a pontoon and then just tie them all together with steel cable that is anchored to turnbuckles on concrete piers on land and let them float.
I doubt a doubled up 2x10 would work well spanning 20' If you intend to use wood I'd think you'd need a lot more posts throughout the pond, not just one set in the middle.
A floating bridge will likely be your easiest and cheapest. It can be built in small manageable sections and almost everything can be a human movable size.
You can build it like a boat dock. It's a method of construction that is used on lakes and seashores all around the country so there is a lot of information available on "how to".
Another option is to get the frame rails used under mobile homes. When old single wides are scrapped the frames underneath are available for a decent price. They could span 40' if you are able to transport and handle steel of that size and weight.
Do not attempt to do a single or double span with regular dimensional lumber unless you break it up into three spans. One span is simply too much. Two spans is at the limit of what regular lumber can do. You can also consider trusses or go to glue lams or LVL's.
Our bridge is made up of (4) 2x12x24' which span a distance of around 22'.
So if you can get a very solid center support then yes it's possible.
However, my bridge is only about 24" wide with deck boards so for 5' wide you will probably need (6) 2x12x24.
Here is picture in prior post!
https://www.doityourself.com/forum/d...en-bridge.html
https://www.youtube.com/watch?v=vn-N172cPbY
https://www.pbs.org/wgbh/nova/lostem...na/builds.html
