Help repairing sliding screen door wheel
Old 04-29-19, 02:31 PM
Received 2 Upvotes on 2 Posts
Hi folks,
Any tips would be great. I have a sliding screen door (for the deck) that kept falling off the tracks. Then I realized one of the bottom wheels is not where it should be. It has fallen into the frame of the screen door. It's either broken, or just unattached. I can't tell if the bottom piece of metal (see attached picture) actually comes apart so you can get to that location and either repair or replace the wheel. I've replaced the screening in the door before, but never the wheel.
Please see the attached picture for a better view of what I'm describing.
Thanks!
Old 04-29-19, 03:11 PM
Received 3,740 Upvotes on 3,356 Posts
Look to the right of the wheel on the side of the frame..... there may be an adjusting screw there to set its height. The picture is just for reference.
Old 04-29-19, 03:35 PM
XSleeper's Avatar
Received 1,838 Upvotes on 1,654 Posts
Generally you don't repair you replace since its usually broken or seized.
Old 04-29-19, 03:43 PM
I posted a generic picture of a roller. Your's may have a similar replaceable assembly.
Old 04-29-19, 04:05 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Lowes or HD usually have a selection of door parts. You can match what you have.
Old 04-29-19, 04:21 PM
XSleeper's Avatar
And you don't take the frame apart, the roller likely just pops right out with a pry bar, and the new one presses in. Does it have a slotted adjustment screw on the opposite side of the frame? Or do these have no adjustment screw?
Old 04-29-19, 04:43 PM
XSleeper's Avatar
Assuming that is an Anderson door, here is one replacement part.
https://www.swisco.com/Screen-Door-R...Rollers/84-020
Old 05-02-19, 02:35 PM
Thanks everyone for the tips. I was able to get the old wheel out and it looks like the one attached in the picture below. Looks like that Swisco site sells it too, but I’ll check the HD first since they’re down the street.
Unfortunately I think when the wheel broke, the screen door fell and two metal pieces of the door became disconnected. See red circle in second picture. Maybe I can put a piece of metal bracing on it.
Old 05-02-19, 04:25 PM
pugsl's Avatar
That shouldn't be a problem. Check top of screen to see if it is pushed up there.
