Tiling Outdoor Kitchen
Old 06-07-19, 09:03 AM
D
We are installing tile on an outdoor kitchen. The longest side of the kitchen is just over 8 feet. Do I need to put in expansion joints? Currently considering very small tile spacing. Would larger tile spacing help with the expansion and contraction?
Old 06-07-19, 09:50 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
You dont want any expansion or expansion joints, the structure the tile is being added to should be robust enough to not flex otherwise the tiles will pop off!
Old 06-07-19, 11:01 AM
Received 1,262 Upvotes on 1,203 Posts
What is the substrate? If going over a concrete pad with expansion joints, you do have to account for those.
Old 06-08-19, 07:21 AM
D
Tile is on the walls of the structure only and it is going over durock. Thank you!
Old 06-08-19, 08:12 AM
P
Received 2,122 Upvotes on 1,899 Posts
Your wall has no expansion joints so your tile should not either.
