What is most effective deck cleaner?
Old 07-05-19, 03:49 AM
K
Received 1 Upvote on 1 Post
I am getting ready to clean the decks on the back of my house and then restain them. I plan on using a pressure washer but not alone. I will use a cleaning agent as well and wanted to get your opinion from actual experience what you all think is the best and most effective deck cleaner to use.
I have used JoMax before and I have most recently use Valspar deck cleaner. I wasn't real impressed with the Valspar cleaner so I thought I would see what you all find works best.
I have also seen something called Wet and Forget but I have never used it.
What do you all think?
Thanks
Old 07-05-19, 04:28 AM
Received 840 Upvotes on 737 Posts
I've heard of wet and forget but I've never used it.
I always use bleach because it's cheap and effective, sometimes I'll add TSP to the mix. Here in the southeast mildew is the main culprit. A lot depends on what you need to clean off of the deck.
Old 07-05-19, 05:38 AM
Norm201's Avatar
Received 725 Upvotes on 641 Posts
There are several other products you can try. KrudKutter is one and I've heard good things about 30 Second Outdoor Cleaner.
