Suggestions for removing stripped 2" deck screws?
Old 08-14-19, 04:02 PM
A
Received 2 Upvotes on 2 Posts
Seven of these are stripped. Should I buy a specialty extractor or do you have any tricks?
Top Answer
08-15-19, 02:58 AM
aka pedro
aka pedro is offline
Received 73 Upvotes on 66 Posts
Why are you removing them? If you're replacing boards just rip the old ones out then cut the screws off.
Old 08-14-19, 04:23 PM
Received 3,596 Upvotes on 3,225 Posts
There really isn't an extractor for that application.
Usually you just wedge a small flat screwdriver under the head and lift the head up while turning.
There are several other tools like a mini wrecking bar and cat's paw that can be helpful but can damage the surrounding wood a bit.
Northern Mike voted this post useful.
Old 08-14-19, 04:28 PM
A
I have a cat's paw and they're still a pain. The 3" screws are really embedded in the joists. Sucks.
Old 08-14-19, 04:51 PM
XSleeper's Avatar
Received 1,808 Upvotes on 1,626 Posts
You could try these, but no guarantee they will work.
https://www.lowes.com/pd/SpeedOut-8-...tor/1000170531
Old 08-14-19, 04:58 PM
I have a pair of wire cutters (dykes) with a sharp edge that I also use to get under the head. Usually with a slight lift/wedging you can turn the screw out. You can't pull the screw directly out. It needs to be turned out.
Old 08-14-19, 05:07 PM
T
Received 69 Upvotes on 64 Posts
Dremel, cut a slot for a flat blade screwdriver might work...
Old 08-14-19, 05:52 PM
A
Good ideas, thanks guys!!
Old 08-15-19, 02:58 AM
A
marksr, Northern Mike voted this post useful.
Old 08-15-19, 05:04 AM
B
Received 258 Upvotes on 230 Posts
If you are replacing the deck boards, chisel/cut board around stuck screw to remove deck board and then use vice-grips (gripping on threaded portion of screw) to rotate out, If not replacing deck boards, suggest cutting parallel faces on screw head (using a metal cutting disc on a dremel like tool). Grab screw head by flats ( using vise grips in a vertical position) and try to unscrew.
Old 08-15-19, 10:47 AM
A
The board was rotten enough to yank it out, which of course exposed the remaining screws. At that point, I used vice grips to remove them.
