Bondo
Old 06-30-23, 06:00 AM
johnam's Avatar
Received 12 Upvotes on 11 Posts
Bondo
Which Bondo product is best for filling small sections of outdoor wood?
Old 06-30-23, 06:19 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Its basically all the same, two part polyester resin, buy the cheapest!
Old 06-30-23, 08:58 AM
Received 50 Upvotes on 46 Posts
I prefer the cream hardener vice the MEKP. It seems smoother and easier to tell when the hardener is properly mixed.
Old 06-30-23, 01:23 PM
Received 839 Upvotes on 736 Posts
What wood do you need to repair?
No filler is ideal for repairing decking. Any wood that is filled should have all the surrounding punky wood removed first.
Old 07-01-23, 05:41 AM
johnam's Avatar
Marq1....That's what I thought/ Marksr.....Bottom rail of deck railing. I've done it before just curious if one product was preferred. Jrsick....Didn't know about cream hardener...Thanks to all.
Old 07-01-23, 08:39 AM
I don't know that one brand would be better than another because wood will shrink/expand with moisture changes and that makes it difficult for any filler to stay put. Ideally you'd replace that board, short of that the better you seal the repair the better chance it has.
