My flagstone patio is developing cracks at the joints. I would like to know how to patch/seal them to avoid water from sipping excessively into the ground. I understand patching is not a water proof method.
What product can be used? How do match the color of the "grout"?
I've had the same problem with mortar joints in a grey flagstone pool deck (pictured below) and a slate walk, stair treads and porch.
I don't think anything is going to last many years, especially with big temperature changes, but I found that using a high-quality outdoor grade grout mix for pool decking was the best product to use and it made cleanup fairly easy too.
I would not recommend using a flowable product from a tube because it will probably have latex or silicone as part of the product which will most likely make a mess of what the joints look like...though it may help seal the water out.
The instability of the base that the stone is set on is the problem, as the ground moves the grout joints crack. That's why paver patios use sand to fill the joints, they have more give.
Your going to have a constant choir if digging out those mortar joints and repai=ring, might want to consider using plyometric sand instead.
thanks Marq1, I think you are absolutely right. I also live in an earthquake zone so not surprised w/ the cracks.
Although given my patio is 25 years old, I would say it has held up well so far. But as you said, cracks will keep coming.
Hello, I'm working with the city to approve the resurfacing of my deck/stairs. I am planning on removing the old wood and replacing it with composite materials. I will be keeping the same concrete footings, pad, ledger board, size, etc. That being said, I'm getting some questions I'm just not sure about as I'm not 100% certain about the terminology. Thanks for any help!
_____
[b]Question from City:[/b] What is framing size and spacing? Beam size and span? Footing size at bearing? Ledger board size and attachment to house? Lateral attachment (R507.9.2)? Please show on drawings more information.
[b]My answer:[/b] Framing size and spacing: 2x8, 16 on center. Beam is 85.5" with a 6' span. Footing size at bearing is 4x4 post on 8" round poured concrete pier. Ledger board is 2x8 and lag screwed to rim joist.
[b]Question for forum: [/b]Do the attached drawings show what they are looking for, or would you add another view or more details somewhere?
_____
[b]Question from city:[/b] Design must comply with 2020 MSRC ([url]https://codes.iccsafe.org/content/MNRC2020P1[/url]) including R507 Exterior Decks ([url]https://codes.iccsafe.org/content/MNRC2020P1/chapter-5-floors#MNRC2020P1_Ch05_SecR507[/url]). Determination of Code compliance is the role of the Plans Examiner. Applicant's role is to please provide drawings that describe the construction in sufficient detail to demonstrate compliance with Code. Please review requirements of 2020 MSRC R507 at [url]https://codes.iccsafe.org/content/MNRC2020P1/chapter-5-floors#MNRC2020P1_Ch05_SecR507[/url]
[b]Question for forum:[/b] That first link is to a paid guide, so that's a non starter and I don't think what they're looking for. Am I to go line by line in this code from the second link and respond to each section as to why my deck is compliant? Much of this technical information is beyond my expertise. Thanks for any advice.
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x813/001_overhead_0654f85e934adfa43fa88b0a4f83bed9b7068ef0.jpg[/img]
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1274/002_side_3dbda7193ee2aade5493978618517d52e2b68b5d.jpg[/img]
Read More
Overall our deck is in good shape, but there are a few spots where the wood started to get eaten away where we watered a potted plant on our deck. The wood is solid, not soft.
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_8339_af47520a8d660c92439d54f3e29a2b6a02b7783b.jpeg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_8338_5ffcbe0352a85e37867d26dc8904f625f8ac62d5.jpeg[/img]
What is the best solution for fixing/improving these few areas?
Should we just leave it and seal it? Should we wood fill it? Read More
