Funny (at least to me) that there's a similar post, but related to the deck floor that I just saw when I went to post this question.
This is in a 30 year redwood deck that's in pretty good condition. This is a railing piece. Carpenter bees made a nest 5 - 8? years ago and then I guess a woodpecker went there for lunch.
I've tried wood filler years ago. Then it dried / cracked after some amount of time.
When we had the deck stained 2 years ago, the painter used a 2 part epoxy with a long nozzle that mixed the 2 parts by the time it got to the end of the nozzle. Not sure of the brand. Recently, most of the epoxy came loose, like marksr talked about in that other thread.
Is that the case? Just resign myself it's a maintenance issue every few years?
It's too long a piece to replace it.
I see that some of the epoxy is still in place - likely locked in to the tunnels the bee made? I guess the upper part should be shaped to lock in the upper part (inverted pyramid?) - that would help a little? But then too much will make the railing weaker / could break?
Yes it will be a continual maintenence issue. You may get more life out of it if you treat the wood with a wood hardener first. It will help the epoxy bond better and maybe last a bit longer.
And keeping it painted will help too. The minute water can seep into the wood, it starts to affect the bond.
Bondo is good waterproof material for filling wood, it's not going to stop the continued decay around the void but probably better than trying to glue that piece in and having a small void that will collect water.
Overall our deck is in good shape, but there are a few spots where the wood started to get eaten away where we watered a potted plant on our deck. The wood is solid, not soft.
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_8339_af47520a8d660c92439d54f3e29a2b6a02b7783b.jpeg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_8338_5ffcbe0352a85e37867d26dc8904f625f8ac62d5.jpeg[/img]
What is the best solution for fixing/improving these few areas?
Should we just leave it and seal it? Should we wood fill it? Read More
Hi all! This is my first time posting, and I would greatly appreciate any advice or ideas that you all can share with me! This is what we have been told regarding the history of the deck (previous owner installed) - the cedar deck was built in Jan. 2022 and not sealed/stained until sometime late that summer. That could maybe be fine in another climate but we live near Seattle, Wa and get so. much. rain. At this time, the deck is covered in black mildew.
We initially thought we could just pressure wash or clean the deck to remove the mildew, but I think that it is either deep in the wood or that they sealed over existing mildew because I cant get anything to remove it. I have tried multiple commercial "mold and mildew" removers and pressure washing and neither appear to make any difference. I also tried sanding a small area, and it looked good.....until the next day when I looked at it and it already had mildew on it! I didn't think mildew grew that fast which is why I am wondering if it could be "in" the wood itself?
I'm considering a couple options, but am unsure if any would really work or if there is a better option. I am really hoping to avoid having to replace all the boards!
1) Pressure wash (knowing there will still be mildew when I am done), dry and apply a coat or two of Zinsser mold killing primer, followed by a solid color deck paint. I don't know if the primer is enough to block the mildew from coming through the paint, and this is a large deck (32x14) so if it bled through, that would be a disappointing waste of time and money. I am also unsure how this would work around the screw holes which all seem to have cracks/mildew.
2) The boards look pretty good from underneath, although I am not sure if the black area in the picture is just the wood or more mildew (the deck is a couple feet off the ground so lots of airflow), so I am wondering if I could just flip them over (and clean/sand/prime right away). If the mildew is actually in the wood it seems like it would eventually make its way to the new top of the board? I've read that flipping the boards can make the standing water worse, and it already seems pretty bad to me especially with all the wet weather we get.
3) I read recently about someone planing the top layer of wood off the deck boards - is this a feasible idea? It sounds like they would have to be removed one by one, run through a rented wood planer, and then put back on to be stained. I would be concerned about hidden spores making their way through the board to repopulate the top with new mildew!
Pictures below of close ups of the boards, any help or advice would be so appreciated! Thank you! :)
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/img_1674_0681f42c8e95450b510ebb26602cd0dcde99d1df.jpeg[/img]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/img_1671_646804bc264a0c2580c91a4535ea6705e6c988e2.jpeg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/img_1672_f3082ee86802b339970c98cdb0096f2fe736b0fc.jpeg[/img]
[img]https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1594x1973/img_1673_656895be524aa3e98e3fcd3f3b578e3c6ed1faa2.jpeg[/img]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/img_1677_36123ea69eede2f0c675c07942c190cf58cbda73.jpeg[/img]
Read More
