Sealing plastic roof panels
Old 10-29-23, 05:40 PM
O
The translucent panels on our deck have deteriorated over 20 years and Im planning to replace them. One problem weve encountered is dirt and mold accumulates on the overlap of the panels. Is there some method or product that could be painted on or placed on the panels when we install new ones to prevent this?
Old 10-30-23, 02:08 AM
Received 839 Upvotes on 736 Posts
It's the nature of the beast. Moisture gets under the lip and over time can mildew. It wouldn't be noticeable if the panels weren't clear. You could use clear caulk on the seams but I don't know how well that would do long term.
Old 10-30-23, 05:07 AM
P
Received 2,180 Upvotes on 1,950 Posts
I've seen a few cosmetic cover-ups. I have seen wood and metal strips attached over the top of the long vertical seams. I have also seen a black strip painted along those areas. Neither does much to keep dirt out but it does make it less visible and the strips look more like an intentional design instead of just dirty.
