Removing a wheelchair ramp
Old 03-10-24, 11:42 AM
K
Hello new homeowner here,
I need to remove a wheelchair ramp and would like to perserve the wood for future deck redo in the back. I have never done a project like this before but I definitely need to get it done asap since it's built around the electric meter and has ruined the meter and needs to be replaced. I tried to look through youtube and couldn't find any helpful vids on taking them apart. Any tips and recommendations are appreciated. Will upload pics soon. Thanks in advanced.
Old 03-10-24, 02:32 PM
Received 4,103 Upvotes on 3,685 Posts
Welcome to the forums.
It was put together.... so it should be able to be taken apart.
Pictures are needed to help you.... How to insert pictures.
Old 03-11-24, 03:39 AM
Received 870 Upvotes on 761 Posts
Basically disassembly is the opposite of assembly - take off the last piece put on first. Likely the railing, then the decking with the framework last. As noted above pics will help us better understand what you have and how to move forward.
