butcher block countertop
Old 05-27-16, 10:47 AM
A
Hi, I'm trying to stain and waterproof a butcher block counter top. The first time I used WATCO Danish Oil to stain it, and then I applied MINWAX Wipe On Poly clear gloss for the shine and waterproof. After drying, I got white spots as showing in the picture. The second try, I use the same stain, and MINWAX Clear brushing Lacquer. I got the same white spots. What am I doing wrong?Name:  IMG_1540.jpg
Size:  26.8 KBName:  IMG_1541.jpg
Old 05-27-16, 11:02 AM
Received 1,198 Upvotes on 1,153 Posts
I don't know that you can use poly on top of oil, each is meant to be the top coat.
Old 05-27-16, 11:35 AM
Received 759 Upvotes on 664 Posts
White or cloudy spots often indicate moisture in the wood although I would have expected that to show with the oil coat also. Like SS I've never heard of anyone applying poly over an oil finish [least ways not for the first few yrs]
