Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
Kitchen design help for converted detached garage
Old 07-07-16, 02:53 PM
B
Any help would be greatly appreciative. We have a detached garage that we bought that has been converted and looking to make it a little bit more functional and cozy. When you walk in the front door it is our laundry room/kitchen. Small space. Right now on the left wall we have a stackable washer and dryer and about a 35 inch gap between the washer and dryer and the hot water heater. We really need to add a kitchen sink and don't know really where to start. Do we just find a 35 inch kitchen cabinet base that allows a sink and then find a sink and then a countertop? If we get a 35 inch cabinet can be get a 20 inch sink and just have a small leftover countertop? Sorry for the silly questiOns. Any help and design ideas or links to products would help. Thank you!
Old 07-07-16, 02:56 PM
Received 740 Upvotes on 646 Posts
Is this a garage that has been converted into an apartment?
Before you get started you need to figure out both the drain and water supply.
pics could be helpful - http://www.doityourself.com/forum/el...-pictures.html
Old 07-07-16, 03:09 PM
Handyone's Avatar
If you want to purchase a cabinet and not build it, the sink base cabinets are available in 36W and 33W (among others). The 36 is too wide, so you need to go with a 33.
Base cabinets are generally built 34-1/2 high.
Note that the most typical kitchen sink is 33" wide. You might or might not be able to fit a 33" sink in a 33" cabinet without cutting the cabinet sides.
Old 07-07-16, 06:17 PM
B
Kitchen help for converted detached garage
Attaching 2 pics. So I am looking to fill the space between the washer/dryer and the hot water heater. The refrigerator will be moved.
Old 07-07-16, 07:16 PM
ray2047's Avatar
I have merged your two similar threads. To avoid confusion please don't start new threads on the same topic.
Old 07-07-16, 07:29 PM
B
sorry about the confusion.. I did not realize I created 2 threads...
Old 07-08-16, 03:27 AM
Besides reconfiguring the plumbing you'll need to get rid of or move the outlet the fridge and microwave are plugged into. I'm not an electrician but there are rules as to how close an outlet can be to a sink, using a ground fault receptacle allows closer but I don't know how close.
Old 07-08-16, 08:23 AM
B
is it a huge undertaking to move the outlet or a huge expense?
what do you guys think about the all in one kitchenette units like this one:
https://www.appliancesconnection.com...FcMbgQodVeILnA
or do you think they are a waste of money and should just piece together the items seperately
Old 07-08-16, 01:08 PM
A lot depends on where the wires come from [how long they are] whether or not it would be a big deal to relocate that receptacle. That all in one unit might be ok but you still have to run the plumbing along with 240 volt for the stove.
Old 07-08-16, 01:22 PM
ray2047's Avatar
Actually no distance requirement from a sink but it should be GFCI. In fact if the inspector considers this a kitchen you need at least two dedicated GFCI protected receptacle circuits. There can be no lights or fixed in place appliances on those two circuits.
