Removing laminate countertops and adding wood countertops
Received 0 Votes
Hi,
I am looking to remove two laminates countertops and replace them with wood countertops. I guess some of the tiles will need to be replaced after removing the countertop.
Any advices on how to remove + install the new ones based on photos provided?
Thanks
Thanks
FIrst picture, would peel off the edging and veneer to see what the top is made of, might take a section out of the middle and pull sides inward to save tile.
Second picture looks like a shelf was added to a cabinet box. Anything underneath showing screws? Looks like it should just slip out if you can figure how it was attaced.
Screws most likely on the microwave shelf, but I doubt any fasteners are in the window ledge. Cut it into three sections with the middle one about 12" wide. Remove it and angle out the two side portions carefully so as not to damage your tile. If you do pop tile, leave them off until your new units are installed, then replace them and grout in place.
IF all you are replacing are these two units, repeat the steps on the microwave unit and just use silicone on the window unit, no screws.
