Trimming countertop lamanite w/o small router?
Old 12-08-18, 03:53 AM
K
If I want to make a formica countertop I have this problem.
I only have a large 1 1/4 HP router. So when I need to trim the laminate what can I do to trim it when I get close to the wall? Is there a good way to trim those that few inches that the router won't be able to do?
I am hopeful that there is and that I won't have to buy a small router just for this one job. Thanks
Old 12-08-18, 07:35 AM
W
Received 27 Votes on 25 Posts
You could remove the counter top, trim the laminate, and then install permanently.
Old 12-08-18, 07:36 AM
XSleeper's Avatar
Received 853 Votes on 781 Posts
If you need to do it in place you can also use a carbide tipped laminate scoring tool and a framing square to score it about 1/16" long. Then use a rasp and file (file downward only, not up) and/or a sander to finish the edge.
Old 12-13-18, 05:23 PM
K
Y
Thanks for the help with this.
Old 12-13-18, 07:40 PM
czizzi's Avatar
Received 15 Votes on 13 Posts
Complete your routering before you install the counter top. Assume that you have a regular laminate router blade attachment for your tool.
