Small surface crack in granite countertop
Old 03-18-19, 08:35 PM
I have a 6-8" surface crack in my granite countertop that barely (if at all) is noticeable by the finger nail. A marble/granite countertop contractor said to use a high density sealant as it will 'fill' the gap and make the crack unnoticeable. This make sense as the crack disappears when water/cleaner is rubbed on. Does this make sense?
Old 03-18-19, 08:48 PM
Received 4,046 Upvotes on 3,630 Posts
Is that cracked from something falling on it or is it a fissure ?
Do you seal your granite ?
A heavy coat of sealer in the crack may hide it.
The other pros will be by later.
(Didn't forget that PM either)
Old 03-18-19, 09:00 PM
I am not sure what the previous owner did but I'll assume no. I have some MIRACLE 511 Porous Plus Sealer I could use if you think it is appropriate.
It actually occurred right after I put a heavy cast iron pot on it from a 350F oven. I am very surprised given granite should be heat resistant.
Old 03-18-19, 09:13 PM
Granite is strong but it always has natural fissures that can open up or become visible.
Miracle 511...... sounds impressive. I've never used it so I won't comment on it.
