Copper Backsplash
Old 08-19-19, 01:59 PM
K
Copper Backsplash
I think I want a copper backsplash behind the stove. I have looked at a lot of different options. I've looked at tin ceiling tile, real sheet of copper, the sheets of copper with different patinas.... I don't like the look of copper after it darkens with a patina. I have a copper sink and I like it, but wish it didn't get so dark or turn green around the edges.
I'm not the type to try to keep it shiny like it was when it was new. I'm fine with how the sink is, but would like something for a backsplash behind the stove that will not change color, is super easy to keep clean and can handle the heat from the stove. I don't know if I want a sheet of copper or some sort of tile. I know I don't want anything too busy. I would never go with plastic that looks like copper(not that it could be used by the stove by heat even if I liked it). Also, there are so many looks and color variations of copper, copper color tin etc., I don't know what would look best.
I have no idea what to do and was wondering if anyone has any suggestions.
Thanks!
Old 08-19-19, 03:41 PM
Received 3,593 Upvotes on 3,222 Posts
What you do is what you want to see. We can't help you with that.
Stainless steel makes a great backsplash behind a stove. I don't believe I'd consider or recommend using copper as that will be hard to keep clean and will change color with grease on it. Tile may be the best way to go.
Old 08-21-19, 10:25 AM
K
Anyone else have any suggestions?
Old 08-21-19, 04:27 PM
P
Received 1,950 Upvotes on 1,746 Posts
Copper oxidizes and darkens so it will always require periodic polishing to maintain that shiny look. It can be lacquer or clear coated but that won't hold up well behind a stove and in the end will end up looking worse. So, if you don't want to do the work to clean and polish copper then I would cross that off the list.
I would consider tile. You have a dizzying array of options to choose from. I can't see from your photo what your vent hood is but I'd just start looking online and in stores and noting what you like.
Old 08-21-19, 04:36 PM
XSleeper's Avatar
Received 1,808 Upvotes on 1,626 Posts
I would suggest that if you want something that looks like copper, you should look into metal laminates. Formica's line is called DecoMetal, and Wilsonart has a Decorative Metals Collection. One of them would surely have something that would trip your trigger.
Laminates may not stand up to heat nearly as well as a real metal surface would, so whatever product you choose, be sure it (and the adhesive) are both rated for use near your appliances at whatever temperature range constitutes "normal use".
But I bet in the long run, a metal laminate might be easier to care for.
Old 08-21-19, 04:43 PM
Shadeladie's Avatar
Super Moderator
Received 366 Upvotes on 295 Posts
Going on XSleeper's suggestion, there are several styles that look nice.
I found this for one:
Hammered Cracked Copper
and this:
Backsplast Panel Cracked Copper
