Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
flexible duct or periscope duct for Kitchen range hood?
Old 11-17-19, 06:47 AM
G
Received 2 Upvotes on 2 Posts
I've got a kitchen range hood I'm installing over an electric range. the run for the duct will be very short -- perhaps 2' or less, and it's exiting right behind the range on an exterior wall. but the space is very tight and I can't go straight out. the hoods is a top vent with an 8" round exit. Can I use that 8" semi-rigid aluminum duct for this application, or alternatively use a short periscope style duct between the studs? I know these are 6" and I'd have to reduce, but again the run is very short. either would probably work, but I want to be sure they're acceptable for the application.
thanks as always!
Old 11-17-19, 07:00 AM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
Semi rigid duct-work has a place but not on a kitchen range hood.
Although you say the run is short it will tend to build up with grease much more so that any smooth wall ducting..
Old 11-17-19, 07:12 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
At 2' I would do whatever fit the application the simplest and neatest and not worry about the type of material.
Old 11-18-19, 04:33 PM
G
thx gentlemen appreciate the help!
