Niche Tile rough edge question
Old 07-31-23, 10:29 AM
I
Received 1 Upvote on 1 Post
Folks,
The tile cut around the Niche in our new shower is not smooth. I don't want to start pulling that tile out as there's no telling where that will end. The overall tiling job is excellent. Is there any aesthetic fix for this issue? Is it common or is it the result of a dull cutting wheel maybe? Note the tile is high glaze,
very polished. See pic.
Thanks
Old 07-31-23, 10:33 AM
P
Received 2,122 Upvotes on 1,899 Posts
I'd use a diamond bit in a Dremel tool to grind the sharp corner down. There are also diamond hand files you can use but Dremel bits are more commonly available.
iceflow voted this post useful.
Old 07-31-23, 11:43 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Kind of hard to see how the tile was installed, every niche I have installed the inside tile used a bullnose to cover up the cut edges so your not seeing a raw tile edge.
Old 07-31-23, 12:35 PM
I
Thank you for the responses. Here's a bigger pic that shows the issue in a clearer light. I'll make a note of the Dremel option. I was also wondering if there is some sort of colored epoxy putty that could be spread in the area to mask the rough edging?
