Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Designing Kitchens and Bathrooms
Reload this Page >
Best way to tile shower corners to prevent leaks?
Old 08-01-23, 05:10 PM
R
will be using 4x10 subway tiles. When it comes to tiling the shower corners I was going to tile the back wall and then butt the side wall tiles. Should I butt the tiles or leave a space (1/16) and use silicone? Or is there a better way?
Old 08-01-23, 06:21 PM
XSleeper's Avatar
Received 1,899 Upvotes on 1,705 Posts
First off, you dont "prevent leaks" with tile, or by the way you lay tile. To prevent leaks you lay tile on a waterpoof surface... Ditra, Kerdi, Wedi, or Redgard... to name a few.
As for how to lay tile in a corner, leaving a 1/16 to 1/8" gap is appropriate. This gap should not be grouted, instead you typically use a color matched grout caulk which comes in sanded or unsanded textures to match your grout.
rock13979 voted this post useful.
Old 08-01-23, 08:20 PM
Received 1,261 Upvotes on 1,203 Posts
Changes in plane - corners - get caulk instead of grout.
As stated, tile and grout/caulk are not waterproof.
Old 08-02-23, 07:00 AM
P
Received 2,103 Upvotes on 1,882 Posts
I'll be the third person to reiterate that tile is not the waterproofing for a shower. There must be a waterproof membrane installed BEFORE tiling.
Old 08-02-23, 09:38 AM
R
Thanks for the advice guys. I have waterproofed with kerdi board. can you tell me if It's best to use a silicone caulk to help minimized mold or a color matched grout caulk would be fine?
Old 08-02-23, 09:46 AM
P
Most color matched caulk is intended for tile/shower use and is mildew resistant.
