Worth fixing interior guest bedroom door?
Old 02-10-16, 12:22 PM
C
Or replace it?
If replace it, how about using the old one as a work bench with saw horses?
Old 02-10-16, 12:45 PM
Received 1,262 Upvotes on 1,203 Posts
Since it's painted, repairing would be easier than a stained door. I would consider fixing this.
Old 02-10-16, 01:06 PM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
Looks like someone tried to force their way though it.
You'll spend as much time fixing that than installing a new panel. Since it's an interior door you can buy per-stained or just paint it white as the current door is. Even buying a whole new pre-hung frame may be easier
If it's a solid door then yes you could use it as a bench top. But if it's hollow I don't thing so.
Old 02-10-16, 02:01 PM
Received 824 Upvotes on 722 Posts
I'd replace it. IMO it isn't worth the time/aggravation of making a decent repair. As Norm stated, it will make a decent workbench if it's solid, hollow core would work but you couldn't put a lot of weight on it.
Old 02-10-16, 04:06 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
Either way, hollow or solid, I vote for replacing the slab.
Old 02-10-16, 04:59 PM
C
Thanks all!
FWIW, it is hollow.
Old 02-10-16, 05:17 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Actually...hollow core can do well for a workstation over sawhorses. No, you can't re-build an engine on them, but for a miter saw, staining platform, or potting table, they are pretty good.
I have 2 sets of 30" bifolds that I kept just for such uses. Being bifolds, I can carry the door and 2 sawhorses in a single trip. Might be more difficult with a single slab.
Old 02-10-16, 05:27 PM
Received 128 Upvotes on 113 Posts
Cheap flat panel door, no way would I waste time trying to fix!!!.
A whole new prehung door would take less time.
