Changing Door to Window
I have a sliding glass door in my master bedroom that was originally a window. The previous owners turned it into a sliding glass door to access a sunroom that they also added. The sunroom is in bad shape now (20+ years after it was built), my yard is pretty small so my wife and I decided we would rather take it down to have more yard space. I found this short how to guide for replacing a door with a window - How to do a Door-to-Window Conversion | Interior Design Styles and Color Schemes for Home Decorating | HGTV
It seems relatively straightforward but I know that oftentimes these guides make projects sound much easier than they really are. Has anyone completed anything similar? Anything not in the guide that I would need? Should I even attempt this or hire a pro? The door is 6ft W and 7 ft H. I have basic carpentry skills.
Any help is much appreciated.
Welcome to the forums! Installing a window in a door opening is much easier than the opposite. Yes, the instructions were very simplistic, as in most TV show type instructions. They can gut an entire bathroom in a 15 second spritz
A couple of things not mentioned. Before the jacks are installed, they failed to mention that you need to install a pressure treated bottom plate, THEN the jacks. Close the opening down to the window's rough opening and install the cripples. I would double the plate in the window opening to allow for proper nailing of a skirt trim, so allow for that in your measurements.
