Removing duct tape glue on vinyl window ?
Would sort of EZ Strip solvent or solution work to remove gook left by the removal of duct tape on vinyl window ?
https://www.homedepot.ca/en/home/p.e...000802249.html
Or try one of the citrus oil based solvents, like goo gone. Spritz it on, let it work a while, then wipe off. Works for me on all sorts of tape and sticker residue....
Be careful with some of these options. While they will work, some of the harsher chemicals like goof-off and paint thinner can end up staining vinyl window frames if they're not cleaned off properly.
