Installing doors
Old 10-22-16, 10:34 AM
X
Installing doors
I'm trying to install or put some doors on this space that I have here on the pics, but I wouldn't know where to start, need some advice. something affordable that would cover that space with a door or doors
measurements are 95 3/4 w by 79 h
here are the pics
http://i67.************/2s1pumt.jpg
http://i66.************/2u8bg5z.jpg
http://i68.************/29zu4ac.jpg
http://i66.************/2guac1j.jpg
http://i64.************/9qhhug.jpg
I'm just trying to close that space and have some privacy, any feedback would be gladly appreciated. also note, I'm a beginner in this kind of things
Old 10-22-16, 03:31 PM
Received 128 Upvotes on 113 Posts
Pictures do not come up.
Where on the planet are you?
Should have been added in your profile.
Old 10-22-16, 03:48 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
This board will not link to pics from tiny pics dot com.
Old 10-22-16, 04:18 PM
Handyone's Avatar
The 79 high is 1" lower than a standard door, but might work. The 8 foot wide might or might not be a problem.
You don't have a lot of choices on doors, which might be good in this case.
Bi-fold or bypass like a closet or patio slider, or maybe 3 each (hinged doors) if you have room for the swings.
Once a picture is up, you will get some better ideas.
Old 10-22-16, 04:51 PM
X
Where csn I uploads pictures too ?
Old 10-23-16, 03:19 AM
ray2047's Avatar
Beter not to upload pictures. Instead just insert them. http://www.doityourself.com/forum/li...rt-images.html Just remember to adjust the width to 600px or less. The height can be 1000px or more.
Old 10-24-16, 04:10 AM
X
Old 10-29-16, 11:26 AM
X
Anybody ? Really trying to install some kind of door here
Old 10-29-16, 01:36 PM
Handyone's Avatar
Covering this opening with doors should be fairly easy. It depends on the privacy you want.
The 79" high is only one inch shorter than a standard door height, so the doors would need cut down.
The cheapest and easiest would be to install bypass closet doors, but offer the least privacy.
You're not being very specific to what you want. You could cover this opening for $200, or $10,000.
Old 10-29-16, 02:09 PM
X
2-300 hundred would like to spend
Old 10-29-16, 03:27 PM
Handyone's Avatar
This is just a quick search to a company that provides sliding door hardware, the same hardware might be available to you locally off the shelf.
Johnson HardwareŽ 2204F SLIDING BYPASS DOOR HARDWARE
The most important thing about saving money is not the hardware. Spend money on the hardware and make the doors simple 3/4" slabs of MDF or whatever.
Old 10-29-16, 07:49 PM
XSleeper's Avatar
I was also thinking about a triple track Johnson hardware sliding door. Three 36" doors might work if you dont mind some overlap.
Johnson hardware is worth every penny. Hang some cheap hollow doors on it. Track will cost more than the doors probably.
