Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Attaching an exterior door into brick/concrete?
Old 10-23-16, 09:55 AM
B
Hi,
Just removed an old exterior door - probably in in place since the 1950s. I was hoping to find a wood stud to nail the new jam, etc. into, but it's a combo of brick & concrete (see picture).
Best way to attach? Tapcon? I think I can get my hands on a .22 nailer as well.
Thanks!
BName:  door.jpg
Old 10-23-16, 10:42 AM
Received 759 Upvotes on 664 Posts
How wide is the opening? do you have room to add a PT 2x on each side?
Old 10-23-16, 12:28 PM
B
I wish! Might get a cat's whisker between the frame and the existing block.
Old 10-23-16, 04:38 PM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
Securing the jamb to the interior stud might be all you can do. Shims and door and window foam will do the rest. Use a good polyurethane sealant on the exterior.
Old 10-28-16, 12:42 AM
GlobalLocky's Avatar
Looks like a perfect application for a sliding pocket/cavity door
