Slide wash room with the bifold is uneven
Old 01-16-17, 03:38 PM
I have my slide wash room with the bifold at the top and the bottom. It's uneven. Do I buy a newer bifold?
Old 01-16-17, 03:48 PM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
For one thing, the guide on the top left side is a little crooked, so the hole might be rounded and enlarged. That could be repaired if its a problem. But to adjust the doors, there is a screw on the top guide (pivot side when the door is open) that you loosen, then you can tap the guide a little closer to the door jamb and retighten the screw.
Old 01-16-17, 04:17 PM
Do I buy a new bifold hitch because you said it top left side is a little crooked, so the hole might be rounded and enlarged. Do I put something inside the hole because it's enlarge now? What?
Old 01-16-17, 04:32 PM
XSleeper's Avatar
I'm just guessing... no way to know or get excited about it if it's not a problem... it just looked funny. It doesn't match the other one so one of them isn't original. Adjust the pivot side of the door then see how it acts.
Old 01-16-17, 04:48 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
1 of 2 different adjustments could be off. Usually the lower one is in a tooth like mount and door can be lifted and slid a couple of notches. The other one is a screw in top hinge that is loosened and hinge slides. On yours it looks like the bottom needs to come out about 2 maybe 3 clicks.
Old 01-16-17, 04:58 PM
Thanks Thanks Thanks Thanks Thanks Thanks Thanks Thanks
Old 01-17-17, 02:05 PM
the began of the door has a hinge but I don't remember the name because I am going to buy a new one. Thx
http://www.doityourself.com/forum/at...ven-bifold.jpg
