Adjust hinges to prevent door from closing itself
Hi all,
The door of my flat has 3 hinges like on the pictures and it tends to close itself, which is annoying.
I'd like it to just stay open however widely it is.
Does anyone know a way to adjust these hinges to allow that?
Thanks
Thanks
Check with local authorities first, entry doors may be required to close automatically where you are.
Regardless, a small doorstop would solve the problem.
The door was not installed plumb, meaning it's leaning which is what is causing the door to open/close on it's own.
To fix, pull out one of the hinge pins and support on the ends and give a gentle hit with a hammer to introduce a slight bow to the part. Need to be gentle as the bow in the pin will introduce friction within the hinge and keep it from opening. Bend too much and you wont be able to reinstall.
Best case, do one, see how it works, need more, do a second, need more, do the third!
The door of my flat
