Removing Interior door and widening help
Old 06-15-17, 09:19 PM
So ive decided to remove the interior doorway from the front door vestibule to my living room and widen the doorway as much as possible which would only be a few inches. i removed the door trim and see the door frame is shimmed on all sides. is shimming required if i will not be putting a door back? could you nail the frame directly to the studs? i've included some pictures of what i'm referring to. Name:  doorway2.jpg
Size:  30.4 KBName:  doorway1.jpg
Old 06-15-17, 10:12 PM
XSleeper's Avatar
Received 1,845 Upvotes on 1,660 Posts
You could remove the shims, but shims are almost always needed behind a jamb to install the jamb (which is slightly smaller) to take up the slack and to plumb it up. If the rough opening is plumb, shims aren't necessarily needed.
