Installing exterior door with Type X drywall
Old 11-14-17, 07:49 PM
Received 25 Upvotes on 20 Posts
What's the best way to install a door that will eventually have 5/8" type X drywall on one side and 1/2" on the other? I'm thinking offset the door 5/8" on the type x side and install thicker trim on the inside then butt the 1/2" drywall up against the trim. Any other ideas? If it isn't obvious what the issue is, the jamb is sized for 1/2" drywall on each side l, so using 5/8" on one side causes the jamb on the opposite side to be recessed 1/8" behind the drywall.
Old 11-14-17, 07:53 PM
XSleeper's Avatar
Received 1,845 Upvotes on 1,660 Posts
Interior side flush with the surface of the drywall so that the trim lays normally. On the outside, the trim can be rabbetted (notched) as needed to hide the 1/8" difference. Exterior trim is usually 5/4 thick, such as brickmold... or something of similar thickness.
This assumes your door is made for a standard 4 9/16 or 6 9/16 wall thickness... and that you will have 4 11/16 or 6 11/16.
You don't butt drywall up against trim.
Old 11-15-17, 04:51 AM
Notch the brick mould. Of course! I have a table saw, so that will be super easy. Thanks!
Old 11-26-17, 05:08 PM
W
Received 13 Upvotes on 11 Posts
Hi, Shim the sheetrock 1/8" where it butts upon the door.
Woodbutcher
