Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
Will spackle fill in peeled paint area on door?
Old 03-29-18, 09:54 PM
B
I have a slight depression on a cheap hollow door about 8 inches long by maybe 2 inches wide where the old paint had peeled away to expose the original wood of the door. I had primed it with Zinser, but it's still lower than the rest of the paint and slightly notiicable.
Can I use some spackle to fill in the depression and then prime and paint it?
Old 03-30-18, 03:47 AM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
You would have better results with joint compound. Spackle is not hard enough, but joint compound you can sand flat.
Old 03-30-18, 04:52 AM
Received 824 Upvotes on 722 Posts
Like X, I always use j/c but spackling will work.
IMO a lot depends on what you have on hand.
Old 03-30-18, 12:23 PM
B
Thanks guys. It's a very minor inperfection so I think spackle will do. Most people would probably just paint right over it, but sometimes I'm ocd.
