Doggie Door
Old 04-13-19, 10:23 AM
F
Received 1 Upvote on 1 Post
Doggie Door
i have a doggie door in my mud room and it is very simple- a hole cut in the wall with a flap in it. If I want to keep the dog inside or outside, I have a metal sheet that slides into a track covering the hole. This was a Kit that I installed. Problem is that in the winter that room gets cold and pipes freeze since the door is not insulated. I want to put in something heavier duty and insulated that will swing both ways- any suggestions?
Old 04-13-19, 10:35 AM
pugsl's Avatar
Received 78 Upvotes on 71 Posts
Put a triple doors. the one you have, another one on other side of opening with a blanket flap in the middle. Not perfect but better than what you have.
