Removing Storm Door Frame
Hi all, i'm trying to remove a storm door from my front door. Never done it and thought it would be easy but running into some issues. I got the door off, but I'm having a hell of lot of trouble with the frame. The right side had screws but the left or top do not, and it looks like maybe they are glue to some wood on the door frame? Anyone have any ideas? Also, i'm not sure if that wood under the frame itself is decorative or was put there for some reason. Thanks!
Pull off the vinyl strip that is covering all the screw heads. It's partly coming undone on the top in your 2nd pic.
