Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Doors, Skylights and Windows
Reload this Page >
I need to install a latch on an interior wooden sliding door
Old 12-22-19, 11:49 AM
D
Question I need to install a latch on an interior wooden sliding door
I need an easy-install latch for an interior sliding door. I need to put it on without boring any holes for set-in hardware. It all needs to be attached to the surface of the door and the surface of where the door goes into vertically where it closes. I need to be able to latch it from the outside when I leave, and from the inside when I come in. The only purpose of the latch is to keep a 10lb. male cat from opening the sliding door, which lets the heat out.
Old 12-22-19, 12:02 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
With the constraints you've put on it about all you could do is use Velcro tape on the door and jamb.
2john02458 voted this post useful.
Old 12-22-19, 12:22 PM
Received 128 Upvotes on 113 Posts
Got a picture so we can see what your seeing?
Old 12-22-19, 12:35 PM
H
Received 283 Upvotes on 243 Posts
A shoelace, 2 push-pins and a staple gun.
Old 12-23-19, 05:44 PM
W
Received 13 Upvotes on 11 Posts
Hi, a piece of 1/4 plywood about 30" High and 4" wider than the door. Put on the side of the door where the cat is and use 2 one gallon jugs of water on the floor to hold the ply wood in place. Works for me.
Good Luck Woodbutcher
Old 12-24-19, 05:00 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Hmm
So that means the door would have two independent latches, meaning you could be on the wrong side of the door with no way to unlatch!
How about some magnets to add some greater opening force!
