Sliding Patio Door - need replacement part
Old 07-02-22, 09:28 AM
C
A contractor replaced the sliding patio glass door at my house couple of years ago. Now couple of plastic parts have crumbled and i am unable to find a replacement for them - as i don't know what they are called...
I am enclosing couple of pictures and will appreciate if someone could tell me what they are called and where i can buy them from?
Thanks in advance
Old 07-02-22, 09:36 AM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
Those are vinyl rail endcaps and they are proprietary parts, which means they are unique to the brand and model of door... only available from the manufacturer. And most of those types of parts are not available as replacement parts. I doubt you will locate them.
Old 07-02-22, 01:32 PM
C
Thanks for your reply, i suspected that all along as i did try to locate them but could not find anything close to it..
do you know anything that comes close to it, so may not be a exact fit but gets the job done....
Thanks
Old 07-02-22, 01:41 PM
XSleeper's Avatar
Not really. You could probably buy some vinyl TrimQuick and cut it to the approximate size, and just stick it on there.
Old 07-03-22, 07:45 AM
C
Thankyou very much for your help...
Have yourself a Great day!!
Old 10-13-22, 05:55 PM
D
Sliding glass door
Try Swisco.com
Old 10-14-22, 06:16 AM
Norm201's Avatar
Received 694 Upvotes on 617 Posts
This can be easily 3D printed.
Go to a 3D forum and ask if someone there would be willing to make it.
You will need to have exact dimensions. (Or provide the old unit or what's left of it as a template.)
If you want, I can take a crack at it. Do you still have the old unit? If so, take several pictures of it from different angles and the flip side.
