Freshvent Ventmax air exchanger.
Old 03-18-14, 07:33 PM
I
I have a noisy fan motor assembly in my Freshvent Vent 1001 air exchanger. I have replaced it once 10 years ago and now cannot find another Motor. It is a half amp motor 120vac with an external rotor that pivots on one single bearing. Has anybody seen this kind of motor I believe it is of German origin. I am having trouble locating one of these fans and motor.
Old 03-19-14, 12:51 AM
Received 3,742 Upvotes on 3,357 Posts
I don't recognize that motor. You may have to take it out and use the services of a company like Graingers where they stock hundreds of replacement and aftermarket motors.
Specialty Motors | Grainger Industrial Supply
Old 10-22-14, 04:55 PM
F
Hello there, I have this same Freshvent Ventmax air exchanger in my home, I'm wondering if you have this installed in your home or some where else, I recently did some research on this machine and found out that its not even for a house, could you please let me know
Old 10-22-14, 06:25 PM
Welcome to the forums.
Their product description talks about home and dwelling installation so I'm not sure where you got that information from.
Lifebreath/living_breathing_home -downloads-Freshvent.pdf
Old 10-23-14, 09:02 PM
F
Thank you for the welcome, and this is the site i found Fresh Vent Solution
it gives information on how this machine works for rooms with storing produce, It may even give info on how to get or order a new motor as well
Old 10-23-14, 09:09 PM
F
maybe its not even the right site for this machine, but thought I would share, reason why i'm asking is because the one I have in my home is always blowing in air, I'm concerned about the winter time bringing in cold air causing it hard to heat in the winter,
Old 10-23-14, 11:01 PM
I left a link to the company you are looking for. It's located in Canada.
The company you linked to is a commercial company in Australia.
Lillianwf voted this post useful.
Old 10-24-14, 01:30 PM
F
ok thanks, I just read the pdf file and see that they use this machine in homes, I just need to read and follow the proper instructions, thanks again
Old 02-10-16, 06:37 AM
freshvent 1001dx air exchanger
Read your post re fan motor. I had problem with same motor. I disassembled and replaced both shaft bearings which I got from bearings canada. I CAN PROVIDE INFO IF YOU ARE INTERESTED.
COULD YOU PROVIDE A PHOTO OR DETAILS ON CONNECTIONS FROM THE MOTOR
(3 WIRES) TO THE PANEL ON THE VENTILATOR. iNDIVIDUAL WHO DISCONNECTED
THE WIRES DID NOT RECORD DETAILS.
tHANKS
REGARDS
Old 11-03-23, 09:12 AM
L
I have this ventilator and need to know what filters and how to put them in. I find only a loose foamy filter in there but would like to replace with the proper filters I don't know how to get info on here so would like the address in Canada for this ventilator.
I left a link to the company you are looking for. It's located in Canada How do I find this link. thanks so much
Old 11-03-23, 02:22 PM
I left that link almost ten years ago. That website is now for sale.
Could mean the company is no longer in business.
If you have a Freshvent Vent 1001..... search that. I found five companies selling the filters.
I did not find the original company online anymore.
The filters are supposed to be metal mesh filters that get cleaned and reused.
Replacements will be over $100 USD.
Old 11-04-23, 11:03 AM
L
Thank you, I wish I had a diagram as to how the system works but can't seem to find anything on line. thank you
Old 11-05-23, 05:11 PM
See if you can get this pdf download. The source is ok.
Your browser may say it's malware. It is not.
If you can't access it.... PM me your email address and I'll send you the manual.
Freshvent 1001 manual - pdf
Old 11-07-23, 07:36 AM
L
It opened right up and I am printing it, thank you so much for all your help.
