Dry vent duct questions
Old 03-16-16, 01:45 PM
I have connected flexible dry vent duct to vent hole in the back of dryer. I doulbe check and there is no leak for from flexble dry vent duct. When I dry the clothes, there is some moisture on tile. Is it ok? I am not sure it is moisture from hot air or not. The reason I ask because I am scare of mold. I have spent lots of monies for mold remediation. I attached pictures for your review.
When we remodeled the condo, we decided to trim hole from so we could buy front load washer. But the laundry area is so small so we bought top load washer instead.
Old 03-16-16, 01:50 PM
It is electric dryer.
Thanksssssssssssssssssss
Old 03-16-16, 03:33 PM
Received 78 Votes on 73 Posts
There just is no great way to run that vent hose in those tight quarters, but you bought the wrong one.
It should be against the law to that type or the plastic hose.
It would take all of 10 sec. for that hose to burn through in a dryer fire.
You also have it so kinked up and crushed there's likely restricted flow.
Sounds funky but I would have used an elbow facing up on the tail piece sticking out of the wall, a piece of solid galv. pipe from the dryer outlet sticking out enough to attach another elbow also facing up and connected the two with this type flex line running the line in a loop.
Whirlpool 5 ft. Vent-4396033RP - The Home Depot
Or better yet buy a kit like this.
Whirlpool Dryer Vent Installer Kit-4396013RB - The Home Depot
By far one of the biggest causes of home fires are caused by dryer fires.
I get to go to at least 3 a year and all had that type line or plastic.
Old 03-16-16, 08:10 PM
Joecaption,
Would you please attach some pictures so I can see what you are talking about?
We used flexible duct to connect to hole from the wall for over 3 years. This time we trimmed flexible duct shorter so it would not restrict the flow.
Old 03-17-16, 06:49 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
That is the foil duct not plastic. I believe that is fine to use.
Old 03-17-16, 12:28 PM
Airman 1994,
You are correct. It is aluminum. My main question is I have seen some moisture on the tile when we dry clothes. I believe it is from hot air from dryer through the foil to the vent. Does it cause mold or not?
THAT IS MY MAIN CONCERN. BTW, we turned on the dryer (after we connect the foil duct to the vent) and checked the airflow and it did not leak.
Mike06
Old 04-15-16, 05:51 PM
Yes, water can cause mold.
Hot air hits cooler tiles and condenses.
