Insulating returns
Old 05-20-17, 02:34 PM
G
Insulating returns
Issue #1:
I'm in southern california about half hour from the coast and have a packaged heat-pump. Are the returns in a vented crawl space required to be insulated? If they aren't and I insulate them anyway how will it effect the performance of the heat-pump?
Issue #2:
An additional return will be required to pass through a vented attic area to pull the hot air on the 3rd floor back down to be cooled. It will be made out of R-8 flex ducting. Are there any issues there?
Issue #3:
There will also be supply ducting running through the same attic area to get cooled air to the 3rd floor. Will R-8 be sufficient?
Your help is appreciated!!
Old 05-20-17, 02:49 PM
Received 1,316 Votes on 1,216 Posts
By vented...... you mean at or above the outside air temperature..... correct ?
In that case.... the return needs to be insulated.
R8 is the better insulated flexible ducting.
Old 05-22-17, 09:28 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Yes insulate everything that isn't in a conditioned space. Also flex can't pass through a wall (against code), must use hard pipe.
Old 05-22-17, 09:42 AM
G
Thank you very much guys!
Old 05-23-17, 10:19 AM
G
Gave up on trying to get answers to all three issues/questions. Too many differences in opinions and answers even from those who claim various codes. Decided to just insulate and be done with it and move on. "Get'er Done"!
