Help identifing make/model of exhaust vent with light
I need to change the bulb in our bathroom exhaust vent. The bulder's clean up crew tossed all boxes and almost all documentation. I am unable to figure out how to remove the vent grill/light diffuser in order to change the bulb. I've pressed in the sides of the plastic grille with no effect. I've also pulled the grille down, but it only comes down about 0.25 inch and has a very solid stop. I'm attaching pictures to help in identifying the make/model or even learn the trick of changing the bulb.
Thanks.
Jav
Thanks.
Jav
That looks remarkable old school for a modern new bath fan. I would think the diffuser would have to come off first if they are separate items, but I can't tell you how, sorry.
I think I'd be on the phone nagging the heck out of them for the brand name or where it was purchased. Should be able to answer that off the top of his head.
Like most all bath fans, you pull the shroud straight down about 2". It should have 2 spring clips on either side. You likely arent pulling it down hard enough. You will likely find a label with model number inside the unit.
